Hi Baolin,
Thank you.
I looked at the spectre online help using command
spectre -h bsource. It describes a voltage controlled voltage source like the following.
vcvs1 (n3 n4) bsource v=gain*v(n1,n2), or
vcvs2 (n3 n4) bsource v=v(n1,n2)-v(n5,n6)
It is similar as the voltage controlled voltage source in SPICE. However, I have one more question. Do I have to write the vcvs in a spectre netlist manually?
I try to instantiate a
bvs from analogLib, but bvs has NOT spectre view. There are auCdl, hspiceD, hspieceS, and symbol views. I don't understand why there is not a spectre view.
Best regards,
Yawei
