Jul 16th, 2024, 10:22pm
question about integral (Read 1623 times)
James Bond
Sep 15th, 2007, 7:57am
Hi, all
I need some hint on how to write an integral model ?
module Integral(Vin,Vout);
output Vout;
input Vin;
analog begin
  Vout <+ idt(Vin);
Can you tell me the problem of this model?
James Bond
Re: question about integral
Reply #1 - Sep 15th, 2007, 8:13am
I tried this, but the output is 0, what's the reason?
module Integral(in,out);
output out;
input in;
electrical in, out;
analog begin
  V(out) <+ idt(V(in),0);
Reply #2 - Sep 17th, 2007, 5:26am
Looks OK to me -- can you post the netlist?  Can't tell from the model if
a) V(in) is zero, so of course V(out) will be zero
b) V(out) is connected badly
c) you're running a dc analysis, where idt() gives 0
James Bond
Reply #3 - Sep 17th, 2007, 10:41am
I have an ideal square wave input,  Vpulse is from analoglib, it has V(in) from 0 to 200mV, frequency is 1GHz, the input is connected to the 'in'. The output is open circuit. I ran the transient simulation.
Could you tell me where might be the problem ? Thank you very much.
James
Reply #4 - Sep 17th, 2007, 10:51am
It works for me.
I remember one simulator I used in the past used to round small voltages (< nV) to zero.  Could this be happening to you?  Try setting a larger input pulse voltage and changing the frequency to 1kHz (period to 1m).
James Bond
Reply #5 - Sep 17th, 2007, 10:56am
I made a mistake, it's working now. I set the input voltage wrongly. Thank you for the hint.
James Bond
Reply #6 - Sep 17th, 2007, 11:55am
I have a triangle output with dc 125mV, how can I reduce the dc voltage to 0V? I tried V(out)<+ idt(V(in),-0.125);,
But it doesn't work. Could you please tell me how can I do this ?
James
Reply #7 - Sep 18th, 2007, 12:31pm
What do you mean, "it doesn't work" -- does the output start at -0.125 like it should?
When you say "triangle" do you mean a ramp?  Surely not a sawtooth -- if you're still using the square-wave pulse, you should get a ramp while the pulse is high and a flat output when the pulse source is at zero.
James Bond
Reply #8 - Sep 19th, 2007, 1:33pm
I am sorry for the confusing.  Please have a look at the picture. The following is my code:
output out;
input in;
electrical in,out;
analog begin
  V(out)<+1000000000* idt(V(in), 0);
How can I reduce dc level of the triangle wave to make it be modulated by sinusoid signal?
Reply #9 - Sep 24th, 2007, 7:51am
I'm confused: which is the input, and which the output?
I thought the output was the rapidly-varying wave, because you want a 0V dc level, which the slow sine wave has.
But earlier you were saying the input was Vpulse.  I can't really tell the shape of the rapidly-varying wave.
The integral operator should not be producing a waveform that varies more rapidly than the input, unless you've got serious problems with numerical noise...
James Bond
Reply #10 - Sep 24th, 2007, 12:28pm
It was my fault. I should have explained this before.
The triangle wave in the pic above is generated by integrating the ideal vpulse from analoglib. The sinusoid signal is another signal generated by another block, I don't have problem with this. Now I want to use this sinusoid signal to modulate the triangle wave and send them to the comparator. So the output of the comparator should be the modulated square wave (PWM).
Here you can clearly see that the sinusoid singal and triangle signal are not in the same level, the triangle wave can not be fully modulated.  I want to modify the veriloga code of the integrator and move triangle wave down to sinusoid level , so it can be modulated. Could you please give me some suggestions ?
Best Regards
James
Reply #11 - Sep 25th, 2007, 4:16am
If you set the vpulse to toggle between -100 and +100 mV, this should fix the dc level.
For the modulation, you could put an ideal multiplier in the module:
module mymod(pulse_in, sine_in, out);
  inout pulse_in, sine_in, out;
  electrical pulse_in, sine_in, out;
  parameter real gain = 1000000000;
  analog begin
    V(out)<+ V(sine_in) * gain * idt(V(pulse_in), 0);
