Aigneryu
Previous I used this model to model the finite delay in tri-state PFD.
module pfd_cp_ena_j (out, ref, vco, ena);
output out; electrical out; // current output input ref; voltage ref; // positive input (edge triggered) input vco; voltage vco; // inverting input (edge triggered) input ena; voltage ena; // PFD enable control parameter real ip=100u; // maximum sourcing current parameter real in=100u; // sinking current parameter real vh=+1; // input voltage in high state parameter real vl=-1; // input voltage in low state parameter real vth1=(vh+vl)/2; // threshold voltage at input parameter real vth2=(vh+vl)/2; // threshold voltage for ena parameter integer dir=1 from [-1:1] exclude 0; // dir=1 for positive edge trigger // dir=-1 for negative edge trigger parameter real tt=1p; // transition time of output signal parameter real td=0; // average delay from input to output parameter real jitter=0; // white edge-to-edge jitter parameter real ttol=1f; // time tolerance, recommend ttol << jitter parameter real tidle=1n; // feedback delay in tri-state PFD
integer state_ref, state_vco, seed; real dt; real rst;
analog begin @(initial_step) begin seed = 716; rst=0; end
@(cross((V(ref)-vth1), dir, ttol) or above(vth2-(V(ena)), ttol)) begin if (V(ena) < vth2) begin state_ref = 0; dt = jitter*$rdist_normal(seed,0,1); end else begin if (state_ref==0) state_ref = 1; dt = jitter*$rdist_normal(seed,0,1); end end
@(cross((V(vco)-vth1), dir, ttol) or above(vth2-(V(ena)), ttol)) begin if (V(ena) < vth2) begin state_vco=0; dt = jitter*$rdist_normal(seed,0,1); end else begin if (state_vco ==0) state_vco = 1; dt = jitter*$rdist_normal(seed,0,1); end end
@(above((rst-0.5), ttol)) begin state_ref = 0; state_vco = 0; dt = jitter*$rdist_normal(seed,0,1); end
// rst=idtmod(2/tidle*state_ref*state_vco, 0, 1, -0.5); rst=absdelay((state_ref&&state_vco), tidle); I(out) <+ transition(-ip*state_ref+in*state_vco, td+dt , tt); // I(out) <+ transition(iout*state, td + dt, tt);
end endmodule
However, I found it is very critical to simulate the feedback delay correctly with time step control of transient simulation. With tidle=1n, and run transient directly, the delay will become 1.xns. If I tighten the maxstep, the delay will approach to 1ns. I thought verilog-A should be able to capture the delay correctly since it is event-driven simulator. And I just do not want to set to tight limits on the maxstep for the sake of speed. Does anybody have any good suggestion?
