Jul 20th, 2024, 4:30am
THD Simulation for fully differential circuit (Read 621 times)
packiaraj
India
Sep 17th, 2007, 5:42am
I want to characterize a fully differential DDA programmable gain amplifier for its THD. The feedback is continuous time resistive feedback.
Can any one help me with the method of simulating THD for this PGA? I am using Spectre.
Packiaraj.V.
boe
Re: THD Simulation for fully differential circuit
Reply #1 - Sep 18th, 2007, 7:27am
Hi Packiaraj,
You can use either an instance of Spectre's built-in device fourier or run a DFT on your output; if you want to use the DFT you need to carefully control the simulator to enforce equidistant synchronized sampling.
Hope this helps
BOE
packiaraj
India
Reply #2 - Sep 19th, 2007, 1:44am
Thanks Boe.
