Aug 15th, 2024, 3:37pm
how to modeling a full differential opamp ? (Read 2743 times)
zhujun134
Sep 19th, 2007, 8:19am
hi,all;
     i am designing a sigma-delta ADC,when i want to model a full differential opamp block,then i can find the parameter of opamp how to influence the performance of modulator,but i can not built a full differential opamp in veriloga,and the opamp can inculde these parameter of slew rate,gain,frequency-gain,rout and so on!
    i have modeled a opamp reference to opamp in ahdlLib in cadence,but i can not work at all.
   would you give me some advice?or give some example?thank you in advance!
View Profile 88206995   IP Logged
alonso
Re: how to modeling a full differential opamp ?
Reply #1 - Oct 30th, 2007, 7:59am
When I had the same problem, I used a macromodel for the amplifier modeling.
I hope it will help.
Alonso
jbdavid
Reply #2 - Nov 30th, 2007, 1:40pm
There are a good number of legacy examples in the forum here.. Use the search function..
Thats why we should have a wiki.. eh?
jbdavid
