hiSkill_11 wrote on Jun 12th, 2012, 11:00pm:Hi, Frank
Question.
When the iprobe is inserted into the frequency dependent path, does it function effectively? For example, op-amp and capacitor based inverting gain(-1) stage in which the feedback is capacitive.
I don't see why there should be any problem with capacitive feedback.
Quote:In addition, when i simulate the loop gain of the cystal oscillator which has three loops, one is the oscillation loop(including all), and the sencond is self biasing loop (including gain element and feedback resistor serialized between the input and output of the gain element), and the third is the oscillation amplitude controlling loop. I can't find a point where I can break all loops simultaneously. Which is the correct way to simulate the gain margin with stb for the crystal oscillator? And how can i simulate the oscillation amplitue control loop? I have to use pstb, right?
I'm not sure how much sense it makes to simulate the (in)stability of the oscillation loop (provided that the simulator finds a "dc operating point" at all). You can probably simulate the stability of a biasing loop or amplitude control loop with a pstb analysis. You have to insert the probe at a point where you have a continuous, non-oscillating signal. If the loops don't interact, you should be able to simulate them separately. Depending on your circuit, you might get similar results for the biasing loop with a faster stb analysis at the (artificial) "dc operating point". If you have more detailed questions, please post a schematic of your circuit.
By the way, the cmdmprobe for differential signals is now obsolete. It is recommended to use the diffstbprobe instead. You can find some more details on my webpage
http://sites.google.com/site/frankwiedmann/loopgain.
