Jul 19th, 2024, 12:29am
Spectre question (Read 3370 times)
vaidy.ts
Spectre question
Oct 17th, 2007, 7:53am
I have a question related to Spectre. Lets say I have a model called "mosfet" with a parameter "beta". I then make a subcircuit called "mysubckt" that uses an instance of "mosfet". But when i try to access the parameter "beta" from within "mysubckt", I seem to be running into problems. I tried referring to it like
mosfet:beta
mosfet.beta
etc
but things didnt seem to work.
Can anyone help?
Thanks, regards
Vaidy
Re: Spectre question
Reply #1 - Oct 18th, 2007, 5:29am
What kind of parameter is it?  Are you talking about an " output parameter"?
To be more specific, for say BSIM3, "vth0" is a parameter, you can set
.model nch nmos level=49 vth0=0.9
There are also what Spectre calls output parameters, eg, gm, gds, etc.; you can't set these (the model computes them), but you should be able to access them for plotting.
And, when you say "access" do you mean plotting, or are you trying to access the value of beta to set something else?  The latter is not possible if your beta is an output parameter; if it's an input parameter, you have to declare a subckt parameter and use it in both places.
bernd
Munich/Germany
Reply #2 - Oct 18th, 2007, 8:29am
Try an inline subcircuit rather tan a subcircuit
inline subckt mysubckt (n1 ... nn)
params ...
mysubckt (n1 ... nn) mosfet ...
ends mysubckt
Bernd
Just another lonesome cad guy
Reply #3 - Oct 18th, 2007, 10:28am
It could even just be that you're referring to the model name rather than the instance name, eg
.subckt mysubckt
m1 (d g s b) mosfet ...
.model mosfet nmos level=49 beta=5
.ends
x1 (d g s b) mysubckt
you should be referring to x1.m1.beta; mosfet doesn't appear in the name.
