dash82
I hope that the code is "synthesizable". I think I have one last problem:
I was using monitor statement for debugging purpose (which will not be a part of my synthesized code)
I am getting garbage values for my variables(in1,out1,out2,temp_u1,temp_u0). However, when I do a mouse over the variables, the value is correct. Could anyone please help ?
Code: -------
module conencoder (out1,out2,in1,clock,reset,first); output out1,out2; input in1,clock,reset,first; reg u0,u1,u2,temp_u0,temp_u1,temp_u2; reg out1,out2;
always @(first) begin out1 <= 1'b0; out2 <= 1'b0; u0 <= 1'b0; u1 <= 1'b0; u2 <= 1'b0; temp_u0 <= 1'b0; temp_u1 <= 1'b0; temp_u2 <= 1'b0;
always @(clock) begin if (reset) begin u2 <= temp_u1; u1 <= temp_u0; u0 <= in1 ;
$monitor($time,"u2 = %b ","u1 = %b ", "u0 = %b ",u2,u1,u0);
else if (!reset) begin out1 <= (u2 ^ u1 ^ u0); out2 <= (u2 ^ u0); temp_u1 <= u1 ; temp_u0 <= u0 ;
// taking two lines due to forum post space formatting. It is one line.
$monitor($time,"input = %b ", "out1 = %b ", "out2 = %b ","temp_u1 = %b ", "temp_u0 = %b ",in1,out1,out2,temp_u1,temp_u0);
end end
Testbench:
module testbench ; reg first,clock,reset,in1 = 1'b0;
conencoder r1(out1,out2,in1,clock,reset,first);
always begin #1 first = 1'b1 ; #1 reset = 1'b1 ; #1 in1 = 1'b1; #1 clock = 1'b1 ; #1 reset = 1'b0; #1 clock = 1'b0; //follow this sequence #1 reset = 1'b1 ; #1 in1 = 1'b1; #1 clock = 1'b1 ; #1 reset = 1'b0; #1 clock = 1'b0; #1 reset = 1'b1 ; #1 in1 = 1'b1; #1 clock = 1'b1 ; #1 reset = 1'b0; #1 clock = 1'b0; #1 reset = 1'b1 ; #1 in1 = 1'b0; #1 clock = 1'b1 ; #1 reset = 1'b0; #1 clock = 1'b0; #1 reset = 1'b1 ; #1 in1 = 1'b1; #1 clock = 1'b1 ; #1 reset = 1'b0; #1 clock = 1'b0; #1 reset = 1'b1 ;
initial $monitor($time,in1,out1,out2);
I think I am doing some mistakes in either displaying or formatting my output.
Thanks in advance.
