IVerify
I'm trying to instantiate a model in Verilog-A where the cell name is different than the model name.
For example: Library Name: lib Cell Name: foundry_cell View Name: symbol Under CDF parameter Model name: model_of_cell
In Verilog-A, I tried: foundry_cell #(.param1...) (.node1(x)...);
When doing this the elaborator says "Cannot find any unit under lib:foundry_cell:symbol in the design libraries". This makes sense as it has no way of knowing the mapping from foundry_cell to model_of_cell. I also tried:
model_of_cell #(.param1...)(.node1(x)...);
This doesn't work, because there is no cell view called "model of cell"
Is there a way I can specify the model name when I instantiate "foundry_cell" in Verilog-A? Is there a parameter for model name that I can use?
-I Verify
