Jul 16th, 2024, 8:23pm
Instantiating a model in Verilog-A (Read 2078 times)
IVerify
Nov 13th, 2007, 7:07pm
I'm trying to instantiate a model in Verilog-A where the cell name is different than the model name.
For example:
Library Name: lib
Cell Name: foundry_cell
View Name: symbol
Under CDF parameter
Model name: model_of_cell
In Verilog-A, I tried:
foundry_cell #(.param1...) (.node1(x)...);
When doing this the elaborator says "Cannot find any unit under lib:foundry_cell:symbol in the design libraries".  This makes sense as it has no way of knowing the mapping from foundry_cell to model_of_cell.  I also tried:
model_of_cell #(.param1...)(.node1(x)...);
This doesn't work, because there is no cell view called "model of cell"
Is there a way I can specify the model name when I instantiate "foundry_cell" in Verilog-A?  Is there a parameter for model name that I can use?
-I Verify
IVerify
Re: Instantiating a model in Verilog-A
Reply #1 - Nov 15th, 2007, 11:27am
Instantiating the cell in this way seemed to work.
model_of_cell #(.param1...) (* integer library_binding = "lib"; *) instance_name (.node1(x)...);
The hierarchy editor will complain that "model_of_cell" cannot be found, but the simulation will run.
