Jul 17th, 2024, 3:29am
How to run corner analysis over parameter analysis (Read 3300 times)
Julian18
Nov 15th, 2007, 9:34pm
Hi, there:
I try to run Corner analysis over parameter analysis like this
loadPcf("xxxxx.pcf")
parameterAnalysis("id" ?values '(90u 100u 110u))
cornerRun()
cornerMeas()
but the results have no parameter result. only corner simulation result.
How to do a corner analysis over parameter analysis?
Julian18
Re: How to run corner analysis over parameter anal
Reply #1 - Nov 17th, 2007, 5:34am
Hi, I try to overcome this but ....
I think I have done something dumb as shown below
foreach(device '("tt" "ss" "ff")
foreach(element '("typ" "min" "max")
modelFile(
'("/xx/xx/1.scs" sprintf(nil "%s" device))
'("/xx/xx/2.scs" sprintf(nil "%s" element))
paramAnalysis("id" ?values '(90u 100u 110u)
paramAnalysis("vd" ?values '(1.62u 1.8u)))
paramRun()
which does not work, seems that foreach statement can not be nested and the sprintf can not give the model file a right section definition.
Can someone give me some tested script to do all that job? It is such a tedious work to manually write down several hundreds corners definition in a pcf file.
Julian18
Reply #2 - Nov 20th, 2007, 7:22pm
any ideas? Smiley
Reply #3 - Nov 20th, 2007, 9:33pm
You should read manual.
I don't think nested foreach statement can't work.
Rather you should rewrite like following:
modelFile(
 list( "/xx/xx/1.scs" sprintf(nil "%s" device) )
 list( "/xx/xx/2.scs" sprintf(nil "%s" element) )
or
modelFile(
 list( "/xx/xx/1.scs" sprintf(nil "\"%s\"" device) )
 list( "/xx/xx/2.scs" sprintf(nil "\"%s\"" element) )
I don't check which is appropriate. But I think first one is appropriate.
About tool usage, read manual or contact with technical support of EDA vendor.
