Hi All,
I needed some help with Verilog Cordic code. The code posted below is open source and protected by GNU GPL. I do understand the Cordic Logic (
http://my.execpc.com/~geezer/embed/cordic.htm ), but was having some trouble with the below mentioned pipelined code implementation. My questions start with Q --.
In cordic.v:
16 bit vector xi, yi and zi are passed as input. Then cordic constants are pre-defined.
Q -- Not sure what “wire [bitwidth+1:0] xi_ext = {{2{xi[bitwidth-1]}},xi};” statement is doing. Is it concatenation and assignment?
Now, @posedge clock, if reset is set, then x0, y0, z0 is initialized to ‘0’. Next, when enable is set, z0 is assigned all bits except the first two. And the first 2 bits are used for the case statement.
Q -- My understanding is that in this case statements, the first 2 bits are used to determine the quadrants and accordingly adjust the quadrant (angle) for xi_ext and yi_ext by 90 or 180 or 270 or 360 degree.. But I am not sure. Any comments ?
Then many instances of cordic_stage are defined and they are passed input values x0, y0, z0 and constants c00 etc.
Q -- I am not sure what “#(bitwidth+2,zwidth-1,0)” in this instance definition does. My understanding is that # value is used to define some delay.
In cordic_stage.v
if reset is set then xo, y0 and zo are set to 0. And when enable is set, value of z is checked. My understanding of cordic logic is that, if say that current angle is 45, and desired is 20, then subtract from the current angle, and make corresponding adjustments on x axis and y axis variables.
Q -- This statement checks if “z_is_pos” and does next operation respectively. I am not sure what “xi - {{shift+1{yi[bitwidth-1]}},yi[bitwidth-2:shift]}” is actually doing. My understanding of cordic is that based on angle adjustments, operations of multiples of 2 are carried out on x-axis and y-axis variable. And {} statement are used for concatenation in verilog.
Again, in cordic.v
xo, yo and zo are in continuous assignment mode and are updated everytime a x12, y12 or z12 value changes respectively.
Q – Not exactly sure how the exact desired angle is obtained in cordic.v. The algorithm that I read, made continous adjustments on ‘current angle’ so that it converged to the desired angle. I don’t see that step happening in cordic.v
I am extremely sorry if I might have annoyed you by asking so many questions. But, any help with the above questions will immensely help me.
Thanks.
Shah.
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version. Applies to all codes herein.
cordic.v
module cordic(clock, reset, enable, xi, yi, zi, xo, yo, zo );
parameter bitwidth = 16;
parameter zwidth = 16;
input clock;
input reset;
input enable;
input [bitwidth-1:0] xi, yi;
output [bitwidth-1:0] xo, yo;
input [zwidth-1:0] zi;
output [zwidth-1:0] zo;
reg [bitwidth+1:0] x0,y0;
reg [zwidth-2:0] z0;
wire [bitwidth+1:0] x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12;
wire [bitwidth+1:0] y1,y2,y3,y4,y5,y6,y7,y8,y9,y10,y11,y12;
wire [zwidth-2:0] z1,z2,z3,z4,z5,z6,z7,z8,z9,z10,z11,z12;
wire [bitwidth+1:0] yi_ext = {{2{yi[bitwidth-1]}},yi};
// Compute consts. Would be easier if vlog had atan...
// see gen_cordic_consts.py
`define c00 16'd8192
`define c01 16'd4836
`define c02 16'd2555
`define c03 16'd1297
`define c04 16'd651
`define c05 16'd326
`define c06 16'd163
`define c07 16'd81
`define c08 16'd41
`define c09 16'd20
`define c10 16'd10
`define c11 16'd5
`define c12 16'd3
`define c13 16'd1
`define c14 16'd1
`define c15 16'd0
`define c16 16'd0
always @(posedge clock)
if(reset)
begin
x0 <= #1 0; y0 <= #1 0; z0 <= #1 0;
else if(enable)
begin
z0 <= #1 zi[zwidth-2:0];
case (zi[zwidth-1:zwidth-2])
2'b00, 2'b11 :
begin
x0 <= #1 xi_ext;
y0 <= #1 yi_ext;
2'b01, 2'b10 :
begin
x0 <= #1 -xi_ext;
y0 <= #1 -yi_ext;
endcase // case(zi[zwidth-1:zwidth-2])
end // else: !if(reset)
// FIXME need to handle variable number of stages
// FIXME should be able to narrow zwidth but quartus makes it bigger...
// This would be easier if arrays worked better in vlog...
cordic_stage #(bitwidth+2,zwidth-1,0) cordic_stage0 (clock,reset,enable,x0,y0,z0,`c00,x1,y1,z1);
cordic_stage #(bitwidth+2,zwidth-1,1) cordic_stage1 (clock,reset,enable,x1,y1,z1,`c01,x2,y2,z2);
cordic_stage #(bitwidth+2,zwidth-1,2) cordic_stage2 (clock,reset,enable,x2,y2,z2,`c02,x3,y3,z3);
cordic_stage #(bitwidth+2,zwidth-1,3) cordic_stage3 (clock,reset,enable,x3,y3,z3,`c03,x4,y4,z4);
cordic_stage #(bitwidth+2,zwidth-1,4) cordic_stage4 (clock,reset,enable,x4,y4,z4,`c04,x5,y5,z5);
cordic_stage #(bitwidth+2,zwidth-1,5) cordic_stage5 (clock,reset,enable,x5,y5,z5,`c05,x6,y6,z6);
cordic_stage #(bitwidth+2,zwidth-1,6) cordic_stage6 (clock,reset,enable,x6,y6,z6,`c06,x7,y7,z7);
cordic_stage #(bitwidth+2,zwidth-1,7) cordic_stage7 (clock,reset,enable,x7,y7,z7,`c07,x8,y8,z8);
cordic_stage #(bitwidth+2,zwidth-1,8) cordic_stage8 (clock,reset,enable,x
