Jul 20th, 2024, 8:28am
Plotting integers in Wavescan (Read 152 times)
Nov 26th, 2007, 4:09pm
I went to plot an internal integer variable of a Verilog-A module and was stunned to see it plotted as a digital bus (graphical representations of the transitions with the value occasionally printed as a hexidecimal number). I could find no way of actually plotting the value. Am I missing something? Is it possible to plot integers in Wavescan and have it treat the value as an integer rather than a collection of bits?
« Last Edit: Nov 27th, 2007, 1:13am by Ken Kundert »
Re: Plotting integers in Wavescan
Reply #1 - Nov 28th, 2007, 8:20am
I had no problem plotting an integer.  Was there something strange about your variable name?
Reply #2 - Nov 29th, 2007, 12:56am
Geoffrey,
   I've now tried it with wavescan run from the command line, and it plots integers fine, just like you showed. But when I ran from within Artist it was a different story. I don't know why they would be different. I have since lost that example, and so cannot duplicate the situation. Now I am confused.
Thanks for trying it.
Reply #3 - Nov 29th, 2007, 6:39am
Ken Kundert wrote on Nov 29th, 2007, 12:56am:
You originally posted on Monday, and by Wednesday night you had already lost the example?  You *are* confused. Smiley
Reply #4 - Nov 29th, 2007, 9:27am
Indeed.
