Jul 20th, 2024, 2:28am
Does the output probe contribute to the  nois (Read 2464 times)
Julian18
Nov 29th, 2007, 4:38am
Hi, there
    when I am simulating noise, usually a resistor or a port are specified as output probe, I just want to know if the output noise comprises the contribution due to the resistor or output port?
Thanks.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Does the output probe contribute to the
Reply #1 - Nov 29th, 2007, 10:26am
Output noise takes into account all the noise of the circuit including the load, NF calculated with a probe eliminates the noise due to the probe.
PS:check Virtuoso Spectre Circuit Simulator Reference for a detailed explanation of how spectre calculates noise quantities.
Hope it helps,
Reply #2 - Nov 29th, 2007, 6:22pm
Running "spectre -h noise" would also give you the information you needed.
