Jul 19th, 2024, 12:24pm
Generate a spectre netlist (Read 2794 times)
achim.graupner
Dec 05th, 2007, 10:15pm
Dear all,
how can I generate a spectre netlist using skill. I want to specify the swtich and stop list as well as destination file name of the skill file.
Is there any better approach than using
envSetVal("asimenv.startup" "projectDir" 'string "./simulation")
simulator('spectre)
design( "$library" "$cell" "$view" )
createNetlist()
the main drawback of this approach are:
- I change my ADE defaults
- the netlist is to be found at ./simulation/<cellname>/<simulatorname>/<viewname>/netlist/input.scs
- a window displaying the  netlist pops up
Any ideas?
Thanks, Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
bernd
Munich/Germany
Re: Generate a spectre netlist
Reply #1 - Dec 6th, 2007, 12:38am
Dear Achim,
Only a solution for the last of your drawbacks
createNetlist( ?display nil )
To get back your ADE defaults, you could probably do something like
t_asimDefaultProjectDir = envGetVal( "asimenv.startup" "projectDir" )
execute your code
envSetVal( "asimenv.startup" "projectDir" 'string t_asimDefaultProjectDir )
Cheers,
Bernd
Just another lonesome cad guy
achim.graupner
Reply #2 - Dec 18th, 2007, 7:33am
Thank you Bernd.
2nd question: I want to remove the full path ./simulation/<cellname>/<simulatorname>/<viewname>/netlist/input.scs after having processed the netlist. I however can only remove that directory after closing df2. This is probably because an ADE session is started.
Any idea how to close the ADE session or how to run the spectre netlister without using ADE?
Achim
Achim Graupner
