Jul 16th, 2024, 10:18pm
parameterize the dimension of variables (Read 3938 times)
Aigneryu
Dec 18th, 2007, 8:59pm
 In verilog, we can parameterize thedimension of the bus, but I found it may not be allowed in verilog-a. Is this true?
In verilog
module abc(out, in);
parameter bitnum=3;
output [bitnum-1:0] out;
input   [bitnum-1:0] in;
But I cannot do this in verilog-a. Is there any way to do this?
I need to create an array of electrical signals while I wish to parameterize the dimension.
Is there a way to achieve the following function?
parameter integer dimension=3;
electrical [dimension-1:0] node_voltage;
Re: parameterize the dimension of variables
Reply #1 - Dec 19th, 2007, 10:15am
This is not a limitation of Verilog-A, rather it is a limitation of the simulator. Are you using Spectre? Spectre has suffered from this problem since Verilog-A was introduced. I can sometimes work around the problem by using 'defines.
Aigneryu
Reply #2 - Dec 20th, 2007, 2:55pm
Thanks Ken,
That's right, I am using spectre in cadence. If I change to verilog-AMS, will it help?
If I change to verilog-AMS, will it require more license compared to verilog-A (license for IUS may be required).
Sincerely,
Aigneryu
Reply #3 - Dec 20th, 2007, 2:58pm
Actually my question is how to make the following code more flexible in terms of parameter. This is a Gaussian filter which I want to use in analog simulation.
`include "constants.vams"
`include "disciplines.vams"
module FIR4 (out, in, gnd, phi1, phi2);
output out;
electrical out;
input in;
electrical in;
input gnd;
electrical gnd;
input phi1;
electrical phi1;
input phi2;
electrical phi2;
parameter real vth1 = 0.0 ;
parameter real vth2 = 0.0 ;
parameter real ctap = 10p ;
parameter real roff = 1G ; //ohm
parameter real ron = 0.1 ; //ohm
parameter real osr = 16;
parameter real fc_anti_alias = 4M;
electrical [0:32] vphi1, vphi2, vc1, vc2;
electrical vsum1, vsum2;
real rphi1, rphi2;
real tap_coeff [0:32];
real c_anti_alias;
genvar m, n, p;
analog begin
@(initial_step)
begin
// initial condition of switches
 rphi1=roff;
 rphi2=ron;
// set cap for anti alias filter
 c_anti_alias=1/(2*3.14159265358979*fc_anti_alias*100);
// load tap coefficients
tap_coeff [0] = 0.126951 ;
tap_coeff [1] = 0.157485 ;
tap_coeff [2] = 0.192665 ;
tap_coeff [3] = 0.232450 ;
tap_coeff [4] = 0.276577 ;
tap_coeff [5] = 0.324536 ;
tap_coeff [6] = 0.375553 ;
tap_coeff [7] = 0.428589 ;
tap_coeff [8] = 0.482361 ;
tap_coeff [9] = 0.535382 ;
tap_coeff [10] = 0.586026 ;
tap_coeff [11] = 0.632602 ;
tap_coeff [12] = 0.673451 ;
tap_coeff [13] = 0.707037 ;
tap_coeff [14] = 0.732048 ;
tap_coeff [15] = 0.747477 ;
tap_coeff [16] = 0.752692 ;
tap_coeff [17] = 0.747477 ;
tap_coeff [18] = 0.732048 ;
tap_coeff [19] = 0.707037 ;
tap_coeff [20] = 0.673451 ;
tap_coeff [21] = 0.632602 ;
tap_coeff [22] = 0.586026 ;
tap_coeff [23] = 0.535382 ;
tap_coeff [24] = 0.482361 ;
tap_coeff [25] = 0.428589 ;
tap_coeff [26] = 0.375553 ;
tap_coeff [27] = 0.324536 ;
tap_coeff [28] = 0.276577 ;
tap_coeff [29] = 0.232450 ;
tap_coeff [30] = 0.192665 ;
tap_coeff [31] = 0.157485 ;
tap_coeff [32] = 0.126951 ;
rphi1 = ((V(phi1) > vth1)? ron:roff);
rphi2 = ((V(phi2) > vth2)? ron:roff);
for (m=0; m<=32; m=m+1)
 begin
   //sampling
   I(vphi1[m], vc1[m]) <+ V(vphi1[m], vc1[m])/rphi1;
   I(vphi2[m], vc2[m]) <+ V(vphi2[m], vc2[m])/rphi2;
   //integration
   V(vc1[m], gnd) <+ idt(I(vc1[m], gnd)/ctap, 0);
   V(vc2[m], gnd) <+ idt(I(vc2[m], gnd)/ctap, 0);
   //following
   V(vphi2[m])<+V(vc1[m]);
   //filtering
   V(vsum1)<+tap_coeff[m]*V(vc2[m])/osr;
V(vphi1[0])<+V(in);
for (n=1; n<=32; n=n+1)
 begin
   V(vphi1[n])<+V(vc2[n-1]);
I(vsum1, vsum2) <+ V(vsum1, vsum2)/100;
V(vsum2, gnd) <+ idt(I(vsum2, gnd)/c_anti_alias, 0);
V(out, gnd) <+ V(vsum2, gnd);
Reply #4 - Dec 20th, 2007, 10:36pm
Seems like a very expensive approach. Why don't you just use the z-domain filter functions?
Aigneryu
Reply #5 - Dec 21st, 2007, 1:00pm
The reason I use this is because for some reason I need to play with the dual phase clocks. And I will also need to make a smooth transition for the switches in order to pass the small signal from the clock ports.
