Sep 19th, 2026, 4:12am
Spectre timeout (Read 2592 times)
achim.graupner
Spectre timeout
Dec 19th, 2007, 12:38am
Dear all,
does anyone has an idea how to set a timeout for spectre. I want spectre to terminate after a maximum given time.
Reason: I start plenty of jobs and I know its expected duration. If something goes wrong (i.e. circuits oscillates at a certain corner, needs ages to converge etc.) it is sufficient that I know that something went wrong, hence there is no need to finish that simulation.
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
bernd
Munich/Germany
Re: Spectre timeout
Reply #1 - Dec 19th, 2007, 1:45am
Quote:
In your .cdsinit add the following "cdsenv" type settings:
envSetVal("spectre.envOpts" "simExecName"
        'string "/path_to_spectreLimit")
envSetVal("spectre.envOpts" "controlMode" 'string "batch")
The first variable sets a different executable for spectre - this
should point to the new "spectreLimit" script shown below, the second
variable will restart spectre for each individual run - this is
required so that you can limit the cputime for each individual
simulation.
spectreLimit :
#!/bin/csh -f
# A script to call spectre with a time limit
limit cputime 100
spectre $*
In the above script the limit is set as 100 seconds, you should
replace this with a value that you have decided is a reasonable limit
to allow most simulations to run to completion, but stop those that
get stuck.
Source:  http://sourcelink.cadence.com/docs/db/kdb/2001/Aug/1843455.html
Bernd
Just another lonesome cad guy
