Jul 18th, 2024, 7:20am
The uncompromise among Transient, HB and ENV??? (Read 2384 times)
aboco
Dec 28th, 2007, 12:45am
Hello everyone,
I am working on LogAmp detector development using ADS tool.
Used topology:
There are the uncompromises among Transient (Trans), Harmonic Balance (HB) and Envelope (ENV) simulations when I try to observe output time domain response as following plots:
The uncompromising points are:
1. Trans simulation introduces very different output steady level (compare with ENV and HB)
2. Trans and ENV simulation show opposite equilibrium-reaching process
Could anyone give me comment on the differences?
Thanks alot for help
aboco
Stefan
Re: The uncompromise among Transient, HB and ENV??
Reply #1 - Dec 30th, 2007, 10:20am
What type of OpAmp/Detector did you use ?
When reaching nonlinearities in the stages, the results may vary quite a lot due to different algorithms from the simulators ...
View Profile 16731287   IP Logged
Reply #2 - Jan 7th, 2008, 12:36am
Hi.
What type of signal source do you use for TRAN and ENV analysis ?
Do you use "VtSine" for TRAN and "V_1Tone" for HB and ENV ?
"VtSine" with phase=0 is Sine wave.
"V_1Tone" with phase=0 is Cosine wave.
You shoud set phase=-90deg in "V_1Tone" in ENV analysis.
And you can use "V_1Tone" even in TRAN analysis.
But still there exists discrepancy about steady state value for TRAN and HB.
Could you show me netlist portions about signal source and analysis definitions ?
« Last Edit: Jan 7th, 2008, 4:07am by pancho_hideboo »
