Jul 18th, 2024, 1:22pm
How to use .ALTER statement for models (Read 2609 times)
kiran123
Dec 31st, 2007, 4:44am
Hi
 In Hspice how to use .ALTER and .INCLUDE statements to change the model files of slow, fast and normal corners
i know that if i use .LIB  statement to include the model file
it can be changed by first using .DEL like below and .DEL with proper one
.LIB  "file1" TT
.ALTER
.DEL LIB "file1" TT
.LIB  "file1"  SS
.END
so similarly how to deal if i am using .INCLUDE statement for Models
Kiran
Re: How to use .ALTER statement for models
Reply #1 - Jan 3rd, 2008, 11:56pm
Hi Kiran,
The .alter block can contain .INCLUDE and .MODEL statements. The .MODEL statement in .alter block replaces the original statement if their model names are identical. Please refer to HSPICE manual for any further details.
Yawei
kiran123
Reply #2 - Jan 4th, 2008, 4:07am
ywguo wrote on Jan 3rd, 2008, 11:56pm:
Hi Kiran,
Yawei
Yawei ,
   are you suggesting me to use .MODEL statment instead of .INC? can you explain me little bit
the main aim is to do fast slow and nom corner simulation using single deck with single run
so earlier when i tried  with below statements  it did not print the "slow" corner relsults where as  "fast" corner results are written to output
.INCLUDE "../Models_fast.sp"
.PRINT TRAN V(DATA)
.ALTER
.INCLUDE "../Models_slow.sp"
.END
thanks for the help on this
