Jul 18th, 2024, 3:39am
reduced noise with more sidebands in PNOISE analys (Read 2240 times)
vivkr
Jan 14th, 2008, 4:51am
I get inexplicable results when using PNOISE analysis. I was just playing with the circuit (a switched-cap amplifier),
and I raised the number of sidebands from Nsb=200 to Nsb=1000, while scaling up the maxacfreq parameter in PSS analysis by
a corresponding amount.
I get more noise when using 200 bands than what I get with 1000. I do not see any error or warning messages in the log and the
circuit is unchanged. How is this possible? Any comments?
Vivek
David Lee
Re: reduced noise with more sidebands in PNOISE an
Reply #1 - Jan 14th, 2008, 1:31pm
This happens on highly nonlinear circuits containing sharp waveforms and narrow pulses.
Does this describe your circuit?
Consider tightening tolerances, and keep increasing maxsideband till the pnoise result converges.
- David
