Jul 17th, 2024, 12:29am
Check Simulator Settings from within module (Read 3724 times)
Stefan
Jan 23rd, 2008, 2:55pm
does anyone know if it's possible to check the simulator options from within a module ?
In the special case, I need to know the settings of fmax of transient noise in AMS (spectre solver).
Kind regards,
Stefan
View Profile 16731287   IP Logged
Re: Check Simulator Settings from within module
Reply #1 - Jan 28th, 2008, 6:54am
Verilog-AMS LRM 2.2 added the $simparam() system function to get values from the simulator; GMIN, for example, is explicitly mentioned.  FMAX is not, so you'd have to check with your simulator vendor and probably request an enhancement.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Mar 19th, 2008, 2:44pm
An approach that works in Spectre is to define a parameter with the fmax value and pass it to the model and to the relevant option of the transient analysis instance.
Cheers,
Marq
Reply #3 - Mar 20th, 2008, 6:11am
Marq -
That approach might work OK if you are writing the netlist.  But if you're developing a Verilog-A model for use in other people's simulations, and they use ADE to generate the netlist for Spectre (where ADE is responsible for taking the FMAX value from a box on the GUI form and putting it in the netlist), then I don't think your approach is viable.
-Geoffrey
jbdavid
Reply #4 - Apr 13th, 2008, 11:42pm
I was hoping that  the $simparam would let me access ANY variable in the Model files used by the underlying spice simulator..
for the LAST project where I needed to get the values of modelfile parameters into the models, I created special subcircuits
in the model files with voltage sources set to the parameter value..
then instantiated those in my model.. and used the voltage connection read the parameter value.
-- in a large design where I might  have many models needing this value it would be quite inefficient.
but it was something that I could do that day with things under my control.
-- now maybe the LRM couldn't tell me about these variables because it relates to a specific simulator function..
but I hopefully simulators will provide more such values..
Alternately, I might do something with a netlist pre-processor.. but that might limit the use of something in a corners tool situation.
jbd
jbdavid
