Jul 16th, 2024, 1:09pm
Single-side band mixer to measure I/Q accuracy (Read 205 times)
neoflash
Mixed-Signal
Designer
Feb 18th, 2008, 4:41am
Hi, folks:
I'm calculating how much spur will SSB mixer see, due to I/Q inaccuracy? For example, if there is 1 degree mismatch for I/Q, how much spur should I see?
ACWWong
Oxford, UK
Re: Single-side band mixer to measure I/Q accuracy
Reply #1 - Feb 18th, 2008, 6:24am
Spur will be about -41 dBc.
In the absense of any other mismatches, nonlinearities or crosstalk you can calculate it by 20*LOG10[tan(IQphaseerror/2)]
Often such things are represented by "image" sideband contours levels on IQ amplitude and phase mismatch Cartesian axis.
« Last Edit: Feb 18th, 2008, 7:24am by ACWWong »
neoflash
Mixed-Signal
Designer
Reply #2 - Feb 24th, 2008, 2:15am
Thanks for the reply.
I agree with -41dbc. However, I think the equation should be sin(delta) instead of tan(delta). They have similar value when mismatch (delta) is small.
ACWWong
Oxford, UK
Reply #3 - Feb 24th, 2008, 5:57am
No it is tan(phaseerror/2) not sin
It comes from the 10*LOG10{[1-cos(phaseerror)]/[1+cos(phaseerror)]} which is equal to 20*LOG10[tan(IQphaseerror/2)]
Look at Razavi RF microelectronics for derivation or
http://ieeexplore.ieee.org/iel5/4138799/4138800/04138864.pdf
A key thing is that in a SSB IQ modulator error vectors which cause the "image" sideband, i.e quadrature phase error and quadrature amplitude error, are orthogonal. Therefore you can null both phase and amplitude error independantly.
neoflash
Mixed-Signal
Designer
Reply #4 - Feb 25th, 2008, 3:33am
Oh... Yes. I think i assumed cos(mismatch)=1 during derivitation. Thanks for the head up.
