Jul 16th, 2024, 10:32pm
Voltage value assignment to a real variable (Read 1929 times)
egarcia
Feb 28th, 2008, 10:10am
I'm new in verilog-ams and I'm trying to reuse a system verilog tetsbench for my mixed-signal validation environment and there is a small issue I would like to address:
I'm able to read an analog value and assign it to a real variable in verilog-D using something called "XMR" function in synopsys discovery tool. By doing this, I'm able to create a checker using my system verilog stuff and it's working fine.  However, this method is tool dependent and I would like to use a more general approach for any other tool (such as mentor ADMS).  How can I assign a voltage value to a real signal?
I tried to access an analog net in verilog-d like this, which is not working and I'm not surprised about it :) :
real_variable = top_level.digital_wrapper_1.digital_wrapper2.spice_netlist.net;
So then I created a vams module in order to do the above instruction (this is just one of my approaches but none of them worked):
`include "disciplines.vams"
module spy();
wreal spy_signal;
analog begin
 spy_signal = top_level.digital_wrapper_1.digital_wrapper2.spice_netlist.net;
The idea is to access the spy_signal from the system verilog testbench but I got compilation errors, and since I'm really newbie I don't know what's the solution.
So, any suggestions of what can I do?
Stefan
Re: Voltage value assignment to a real variable
Reply #1 - Feb 29th, 2008, 12:48am
I think I remember something like this :
// declare internal node, look for inherited connections for correct syntax
(* node=/toplevel.... *)
// then you could do
assign real_output = V(node);
Stefan
View Profile 16731287   IP Logged
