Jul 18th, 2024, 3:23am
Many voltage sources in cadence (Read 1882 times)
VerilogANovice
Mountain View
Mar 12th, 2008, 1:06am
My circuit takes in 1024 voltage values (e.g. 1V, 0V) for memory addressing purpose. How, instead of instantiating 1024 voltage sources in Cadence, is there any better way to input the 1024 values into our circuit?
Thanks.
Stefan
Re: Many voltage sources in cadence
Reply #1 - Mar 12th, 2008, 1:40am
Use a verilog-A model with a large bus.
e.g.
module analog_sources(out)
electrical [0:1023] out;
output out;
analog begin
V(out[0]) <+ 1.0;
V(out[1]) <+ 0.0;
// you can use generate statements as well I guess ...
View Profile 16731287   IP Logged
