Aug 15th, 2024, 6:34pm
Verilog-A: Need to add effect of MOS models (Read 3596 times)
hvnmos
Mar 24th, 2008, 8:16am
How can the effect of different MOS Or Passive models be implemented in a verilog-a model?
For example:
I want to model a resistor. The resistance should change depending on if the passive models are nominal, low or High.
So in case of nominal models resistance should be 1K, for low it shoule be 0.8K and for high it should be 1.2K
hvnmos
Re: Verilog-A: Need to add effect of MOS models
Reply #1 - Mar 24th, 2008, 12:18pm
Seems like this is not really Verilog-A specific; if you can do it for a built-in resistor, you can use the same technique for Verilog-A models.  Eg, using "sections" in spectre libraries to set the sheet rho for the model.  You can set up a Verilog-A resistor with a sheet rho parameter, too.
hvnmos
Reply #2 - Mar 25th, 2008, 1:46am
If, sheet resistance is passed as a parameter. We still would have to change the parameter for a different corner. Or would it get changed on its own.
Is there no possibility, of having a conditional statement included in the verilog-A code that could somehow find out what model we are using and change the sheet resistance value on its own?
hvnmos
Reply #3 - Mar 25th, 2008, 5:52am
How do you change the model?  Certainly, the V-A model can't read your mind.  :)   How do the other devices "find out" what model you're using?
In many foundry libraries, you include the library with a statement like this in your netlist:
.LIB '/path/to/file' TT
where TT is for the nominal/typical model, and you use SS or FF for slow and fast.  The way the library file is constructed, there are global parameters that are set differently for TT,SS,FF, and the .model cards use these global parameters.
There is no Verilog-A construct for asking which LIBrary or corner (TT/SS/FF) you are using.
hvnmos
Reply #4 - Mar 28th, 2008, 2:29am
I have done following to implement what I wanted:
I have instantiated a spice primitive, a resistor of 1K. Applied a 1V source across it.
Measured the current through that resistor.
Compared it with predefined values, that I would expect. And found out if my resistance is low or High or Nominal.
It works well.
hvnmos
