Jul 16th, 2024, 10:18pm
Question for PLL examples in Verilog-AMS (Read 2504 times)
tuyettrinh
Apr 07th, 2008, 10:21pm
Hi there,
I just download an example for PLL code in Verilog-AMS from this website, but none of PLL's module (cp, fd, vco, ...) works.  For example, the compiler complains about reg, always, assign ... are future reserved keyword.  I am using SpectreHDL compile.  Please let me know if I am using a wrong compiler.  Thanks a lot.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Question for PLL examples in Verilog-AMS
Reply #1 - Apr 8th, 2008, 2:39am
Spectre will not be usable with this PLL model, you will need to use AMS Designer as that is the mixed-signal tool. Spectre would allow Verilog-A models -- using the analog subset of Verilog-AMS -- but it does not support the digital and mixed-signal parts that the PLL model uses. reg, always, and assign are keywords from digital Verilog that Spectre does not know how to use. AMS Designer will have no problems with these.
Cheers,
Marq
« Last Edit: Apr 8th, 2008, 5:51am by Marq Kole »
