In my design I need to do long transition simulation and control 2 nodes A and B.
In working mode that interests most of the blocks conected to A and B are in powerdown,
but influence nodes A and B by their impedances.
If I generate full netlist, simulation will continue several days.
So, I want to replace non-functional blocks by verilog-A models.
For it I need to characterize theirs input impedances. Eldo allows this possibility, providing so-called
"PORT"-feature, that permits to extract Z, X, Y - parameters. But unfortunately, documantation isn't clear.
My task is as follows. I have blackbox with only interface pin AAA. It has complicated architecture,
but finally inside there is connection to ground. I want to extract its Z parameters. What could be my setup.
I tried with following one (very simple), trying to measure the value of resistor.
Code:*--------------- Z-parameter extraction test
Vin in 0 0 AC 1
R1 in 0 500
*R2 out 0 500
*C1 out 0 1n
.AC DEC 1 10 100000
.plot AC VDB(OUT)
V1 in 0 iport=1 rport=50
*V2 out 0 iport=2 rport=50
.plot ac YR(1,1)
.print ac YI(1,1)
.Ffile Y SINGLELINE test_param_y.par Hz ri
.plot ac ZR(1,1)
.print ac ZI(1,1)
.Ffile Z SINGLELINE test_param_z.par Hz ri
.plot AC SR(1, 1)
.print AC SI(1, 1)
.Ffile S SINGLELINE test_param_s.par Hz ri
.end
File test_param_y.par looks like
Code:! Data from zparam_extract_test
# HZ Z RI R 5.000000E+02
1.0000000000000000E+01 0.0000000000000000E+00 0.0000000000000000E+00
1.0000000000000003E+02 0.0000000000000000E+00 0.0000000000000000E+00
1.0000000000000005E+03 0.0000000000000000E+00 0.0000000000000000E+00
1.0000000000000007E+04 0.0000000000000000E+00 0.0000000000000000E+00
1.0000000000000000E+05 0.0000000000000000E+00 0.0000000000000000E+00
Maybe somebody did it already in Spectre. How setup should be done?
Thanks in advance.
Pavel.
