Jul 17th, 2024, 12:30am
Turning on white_noise in a switch (Read 3423 times)
DaffyDuck
Apr 16th, 2008, 2:23am
Hi All,
I am trying to model the white noise due to the switch resistance with the following statements:
if ( V(ps,ns) > thresh )
     V(p,n) <+ ron * I(p,n) + white_noise(4*`P_K*$temperature*ron, "thermal");  // (A)
else
     I(p,n) <+ 0;
Got the "error" message - analog operator embedded in conditionally executed statement or expression.
I tried to do an assignment to a real var, eg.   noise = white_noise(4*.....  ), and then add "noise" to the contribution statement (A) in place of the lengthy white_noise expression. But I got the error message to the effect that small-signal functions cannot be assigned.
What's the way to do it? Shocked
Stefan
Re: Turning on white_noise in a switch
Reply #1 - Apr 16th, 2008, 2:40am
Add white noise to an isolated electrical node.
Take the voltage from that node and add it to your desired variable/statement/whatsoever.
View Profile 16731287   IP Logged
DaffyDuck
Reply #2 - Apr 17th, 2008, 1:22am
Hi Stefan,
Thank you! That works.  :D
Reply #3 - Apr 17th, 2008, 11:09am
Another approach would be this:
V(p,n) <+ white_noise(4*`P_K*$temperature*ron, "thermal");  // (A)
     V(p,n) <+ ron * I(p,n);  // (A)
else
     I(p,n) <+ 0;
Verilog-A's value-retention rules say that, if you contribute to the flow (I), then all potential contributions are discarded.  Now your white_noise call is not inside the if() statement.
BTW: I personally believe the error from your simulator is incorrect.  white_noise is *not* an analog operator along the lines of idt() or absdelay(); it appears in "4.5 Analysis dependent funtions" rather than "4.4 Analog operators" in the Verilog-AMS language reference manual (2.2).
