Scott Flinchbaugh
newbspec,
You should read the SpectreMDL User Guide to get more familiar with the SpectreMDL syntax.
The for, while and until are not supported.
To iterate over a variable using MDL there is a "foreach" statement. To implement your for loop you should do the following:
foreach insig from swp( start=500, stop=800, step=100 ) { run timedelay as theparms }
Alternatively, you can also explicitly state the parameter values as follows:
foreach insig from { 500, 600, 700, 800 } { run timedelay as theparms }
There is also a binary search and multiple variable search (optimization) capability in SpectreMDL, please review the reference manual for more information on them. Examples are provided.
Thanks, sflinch
