Jul 18th, 2024, 1:32am
Loops in Spectre MDL (Read 3413 times)
newbspec
Apr 21st, 2008, 10:44am
I'm new to Spectre and want to do a binary search using MDL.  I'd like change a the input period on each call to trans.  Can I do this in Spectre MDL?
Are statements like for, while and until available in MDL?
The following flags the "for" as an invalid statement in MDL.
for (insig=500; insig<800; insig=insig+100) {
  run timedelay as theparms
Thank you.
Scott Flinchbaugh
Re: Loops in Spectre MDL
Reply #1 - Apr 21st, 2008, 3:37pm
newbspec,
You should read the SpectreMDL User Guide to get more familiar with the SpectreMDL syntax.
The for, while and until are not supported.
To iterate over a variable using MDL there is a "foreach" statement.
To implement your for loop you should do the following:
foreach insig from swp( start=500, stop=800, step=100 )
Alternatively, you can also explicitly state the parameter values as follows:
foreach insig from { 500, 600, 700, 800 }
There is also a binary search and multiple variable search (optimization) capability in SpectreMDL, please
review the reference manual for more information on them.  Examples are provided.
sflinch
View Profile flinchba   IP Logged
