Sep 17th, 2024, 9:44pm
signal generator output voltage (Read 4968 times)
aaron_do
May 02nd, 2008, 9:08pm
when we run a simulation using a PORT element, and set the output voltage to V, it will actually be a voltage source with a voltage of 2V and a 50 ohm resistor. Therefore, when you match your circuit to the PORT, you will get an input voltage of V.
So does the same happen in measurement for a signal generator? Does it assume a matched load?
thanks,
Aaron
Re: signal generator output voltage
Reply #1 - May 2nd, 2008, 11:35pm
aaron_do wrote on May 2nd, 2008, 9:08pm:
It depends on Signal Generator you use. So you should read manual of SG you use.
In SG, voltage is defined as RMS value. While, you can set Peak, Peak-Peak, RMS as voltage value in FG(Function Generator)
So if SG supports Terminating Voltage Value setting, you set Vrms then get Vrms at matched load.
If SG supports Open Voltage Value setting, you set Vrms then get Vrms/2 at matched load.
If your SG doesn't have such mode and SG is for uWave, it must be Terminating Voltage Value setting.
Usually their voltage units are denoted as dBu and dBuEMF.
For example, Agilent E4438C Signal Generator support following SCPI command to change display amplitude unit.
   "DISP:ANN:AMPL:UNIT {DBM|DBUV|DBUVEMF|V|VEMF}"
« Last Edit: May 3rd, 2008, 4:52am by pancho_hideboo »
aaron_do
Reply #2 - May 3rd, 2008, 4:44am
thanks.
that was very helpful Smiley
