Jul 17th, 2024, 10:22am
how to stop a transition filter in verilogA? (Read 2227 times)
liuqian0428
May 13th, 2008, 1:10am
Hi, every one.
I want to genrate some simulation stimulus in VerilogA. one of the pin is inout, so this pin must floating when it is a output.
I use the transition filter to pass the value to the pin, but I don't know how to stop the transition filter when I need?
Thank you so much!
jbdavid
Re: how to stop a transition filter in verilogA?
Reply #1 - Oct 9th, 2008, 6:32pm
In analog changing the network connections on the fly can lead to simulation convergence issues..
you might rather stick a resistor in series with the driver and change the resistors value depending on the drive state..
bmslib (see my other recent answer today) contains and example switch sw_no which is proabably the best way to define such a variable resistor.. since the ratio of ron to roff is really high..
jbdavid
