Jul 17th, 2024, 7:19am
passing parameters in AMS-simulator (Read 2789 times)
Pavel
Lausanne/Switzerland
May 23rd, 2008, 1:37am
I want to compare the behaviour of my schema in environments - ADE and AMS.
The schema includes some sources, taken from analogLib, that are parametrized.
In ADE it's OK - I pass parameters via dedicated option in ADE.
But how should I proceed in AMS - add CDF parameters for concerned sources or there is more simple way
somewhere in AMS interface.
Thanks in advance.
Stefan
Re: passing parameters in AMS-simulator
Reply #1 - May 23rd, 2008, 1:54am
I don't get it.
In Cadence you can use the ADE Frontend for spectre or AMS simulator. So the look'n'feel is the same.
Stefan
View Profile 16731287   IP Logged
Pavel
Reply #2 - May 23rd, 2008, 2:12am
Hello Stefan,
Thanks for response. But how to acces/select AMS-simulator in ADE.
If it's long to explain, could you tell me in what manual can I get this information.
Regards.
Pavel.
