Aug 17th, 2024, 11:05am
SPICE syntax re: differential noise evaluation (Read 864 times)
joel
Jun 17th, 2008, 8:56am
 I wonder if you smart people could answer a how-to question for me.  I'd like to evaluate the small-signal noise of a differential opamp.  The spice manual explains that the .noise statement takes two arguments.  The first is the output variable defining the output voltage from which the noise is evaluated.  The second is the indepenant source to be used as the noise input reference.  So if I want to evaluate the noise at the differential outputs of an opamp with single-ended input, I'd type
.noise v(outp,outn) Vinp
Where outp, outn are the output nodes of the circuit, and Vinp is the independent voltage source defining the voltage of the input node of the circuit, e.g. Vinp inp VCM 0 AC 1 .
This seems to work. But if I want to evaluate the noise of the circuit with a differential input configuration, do you know the syntax?  I'd be defining the input like this:
Vinp inp VCM 0 AC 0.5            $inp positive polarity input node
Vinm inm VCM 0 AC 0.5 180    $inm negative polarity input node
My confusion is that I'm now driving the circuit with two independent sources.  Maybe it doesn't matter, or I need just do a 6dB adjustment?
I hope my question make sense.  Thanks for any knowledge you can offer me!
Frank Wiedmann
Munich, Germany
Re: SPICE syntax differential noise evaluation
Reply #1 - Jun 17th, 2008, 9:46am
Use the ideal balun from http://www.designers-guide.org/Analysis/diff.pdf and take the voltage source at the differential input as reference.
joel
Reply #2 - Jun 17th, 2008, 12:42pm
Thanks, that sounds perfect!  Please excuse my ignorance and let me ask another question.  The balun subckt definintion contains two independent voltage source definitions:
V1 3 5
V2 2 7
These statements seem to specify the source & reference nodes, but not the potential between them.  I'm more accustomed to, for example,  V1 3 5 0.75V .  Could you comment on how these two statements behave in the subckt?
 thanks in advance, /jd
Reply #3 - Jun 17th, 2008, 6:58pm
Hi Joel,
Which cell do you use in analogLib? I use ideal_balun. The subckt for it is shown below in spectre language.
subckt ideal_balun d c p n
    K1 ( d 0 c n ) transformer n1 = 2
    K0 ( d 0 p c ) transformer n1 = 2
ends ideal_balun
Yawei
Frank Wiedmann
Munich, Germany
Reply #4 - Jun 17th, 2008, 11:17pm
joel wrote on Jun 17th, 2008, 12:42pm:
V1 3 5
V2 2 7
The voltage across these voltage sources is zero. They are used to measure the current flowing through them and are referenced by the current-contolled current sources (F elements).
