jbdavid
man - I even remember that one.. and I quit using spectre verilog after a bad experience in 2000 (with minor exceptions) your verilogxl executable needs to be built with the vmx extensions .. If you look in the 443 open book, I think you can find the instructions there.. -- maybe you need to just change your path to use the "right" version of VXL that has the vmx extensions built in. ??
this may not really help you since cadence has changed the setup in subsequent years, and I refuse to touch it now.. AMSD is much better! goodluck
