Aug 15th, 2024, 9:36pm
Issues in simulatingwith spectre-verilog simulator (Read 3726 times)
paddu
Jun 19th, 2008, 11:48am
 I am getting the following error when simulating verilog with cadence spectreverilog option. I am simulating the verilog code by importing from icfb. If anyone know why this error is coming plz let me know.
Error - verilog-xl executable 'verilog.vmx' cannot be located from $PATH
Please specify correct location in Digital simulation options
suresh
jbdavid
Re: Issues in simulatingwith spectre-verilog simul
Reply #1 - Jun 19th, 2008, 1:43pm
man - I even  remember that one..  and I quit using spectre verilog after a bad experience in 2000 (with minor exceptions)
your verilogxl executable needs to be built with the vmx extensions ..
If you look in the 443 open book, I think you can find the instructions there..
-- maybe you need to just change your path to use the "right" version of VXL that has the vmx extensions built in. ??
this may not really help you since cadence has changed the setup in subsequent years, and I refuse to touch it now..
AMSD is much better!
goodluck
jbdavid
