Aug 15th, 2024, 5:24am
save DC oppoint in spectre (Read 4652 times)
analogue_guy
Jul 03rd, 2008, 4:42am
Hi
the spectre command : save <instance_name>:oppoint does not work for me. (like save M0:oppoint), I got the following error message:
'M0': Does not have a terminal named 'oppoint'
Do you have any idea what can be the problem?
I want to save DC operating point data during DC sweep...
Re: save DC oppoint in spectre
Reply #1 - Jul 3rd, 2008, 4:58am
I thought you were supposed to do something like
op1 dc oppoint=screen
analogue_guy
Reply #2 - Jul 3rd, 2008, 11:40am
Actually I want to run DC sweep simulation (like vary the drain voltage or gate voltage) and i want to plot some values of the operating points (like gm, Cgg...). So, I do not want only one value, rather a function ...
similar thing as the method known as gm/Id
Reply #3 - Jul 7th, 2008, 4:55am
What about
 save <instance_name>:all
