Aug 16th, 2024, 10:03am
question about .meas in hspice (Read 5473 times)
daisy
Jul 23rd, 2008, 7:22pm
Hi!
I'm simulating a low pass filter and I want to see the frequency point when the output value decreases 3dB.I wrote the statement like this:
.meas ac gainmax max vdb(vout)
.meas ac band find f when vdb(vout)='gainmax-3'
however,there is a warning in the .lis file,saying that the band is not defined.So how should I describe the statement?
Thanks a lot!
daisy
View Profile daisy   IP Logged
Re: question about .meas in hspice
Reply #1 - Jul 24th, 2008, 1:07am
Hi Daisy,
It seems that the simulator does not identify what f is. When I try your .measure card. It report the following warning message in the listing file.
**warning** could not identify variable type f
I simulate successfully with the following cards.
.meas ac f3db when vdb(vout)='gainmax-3'
Please note that time or frequency are independent variables in a HSPICE simulator. However, we have never quote a variable like frequency or time in SPICE.
The .measure syntax is
.measure <DC|TRAN|AC> result when out_var=val
where result is time for TRAN and frequency for AC. They are independent variables.
Best regards,
Yawei
daisy
Reply #2 - Jul 24th, 2008, 3:11am
Hi! I have simulated successfully with your cards.
Thank you for your help!
daisy
ywguo wrote on Jul 24th, 2008, 1:07am:
Hi Daisy,
Best regards,
Yawei
