Jul 21st, 2024, 2:32am
spectre simulation setup for warnings and errors ? (Read 2726 times)
taofeng
Belgium
Jul 24th, 2008, 6:58am
  I am wondering how to make sure I can see all the warning and error messages ?
thanks,
Jeffrey
Re: spectre simulation setup for warnings and errors ?
Reply #1 - Jul 25th, 2008, 4:12am
taofeng wrote on Jul 24th, 2008, 6:58am:
I can't find any design issue in your post.
Your question is not design issue but simple usage of very specific EDA vendor's tool.
Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ Circuit Simulators".
Usually warnings which exceed some limit numbers are suppressed in Cadence Spectre.
Do you want to deactivate this suppression of warning ?
taofeng
Belgium
Reply #2 - Jul 25th, 2008, 5:51am
yes, you are right !
Reply #3 - Jul 29th, 2008, 10:05pm
Add the following to netlist.
 aho  options  maxwarnstologfile=3000
See the results of "spectre -h options"
maxwarnstologfile=5
      Maximum number of times any warning message will be
      printed to the log file per analysis. Note that this
      option has no effect on warnings printed as part of
      parsing the netlist. Please use the -maxwarnstolog
      command line option to control the number of all
      warnings printed to the log file.
