jbdavid
So Analog lib is specifically designed not to support AMS using its views since most of them call spectre primitives that are already supported.. for YOUR own library, if you are working inside CADENCE (ie icfb) for the veriloga, the cell you are instantiating SHOULD already exist in a library and have a symbol view. then when you are done editing the veriloga, there is some parsing done to establish the link between the library you reference and the instances you include (this is the info inside the pc.db file in the CDB format..) -- if you are working in a pure netlist environment, you just need to make sure that the element you instantiate can be found in one of -Spectre builtin primitive -model files included in the simulation setup -a module defined in one of the verilog files included in the simulation. -- Hopefully not more than one.. (ie don't make a resistor model called "resistor" !!!) HTH jbd
