Sep 23rd, 2026, 6:48am
if statement (Read 2369 times)
sprun
if statement
Aug 18th, 2008, 1:33am
Hi everyone, I have another problem when writing my verilog-A code. The case is whenever I put a if statement embedded in another if statement, the simulation cannot even start.
Is this another forbidden in verilog-A syntax? But I didn't found it. Hope somebody could help. Thanks a lot!
Re: if statement
Reply #1 - Aug 20th, 2008, 5:36am
It's not forbidden to have nested if statements.  What's going inside the if statements, though, could cause trouble.  I'd try a simple assignment, such as:
if (x > 0) begin
  if (x > 10)
    y = 6;
  else
    y = 8;
end else begin
  y = 0;
I(out) <+ y;
and see if your simulator has trouble with that.
Another thing to watch out for is making sure you've got your "else" associated with the correct "if" -- indentation is not significant, so:
if (x > 0)
  if (x > 10)
    y = 6;
else
  y = 8;
the "else" on line 4 corresponds with the "if" on line 2, not the line 1 that it's indented to match.
