Jul 21st, 2024, 6:37am
how to know "ad as pd ps" parameter? (Read 8021 times)
xwj623
Aug 18th, 2008, 10:53pm
Are the following two formula  correct  which i used to calc the four parameter used in spice?
       ad(as)=W*L
        pd(ps)=2(W+L)
Or what should i use?
they mazed me very much.
vivkr
Re: how to know "ad as pd ps" parameter?
Reply #1 - Aug 19th, 2008, 5:57am
What are the W & L here? Are these the W & L of the gate? Then, your formulae are all wrong.
You cannot know the diffusion dimensions for source & drain just by looking at the schematic. This
depends on the minimum width allowed for these by the design rules.
If I consider source or drain, then 1 dimension (let's call it the length, Ldiff) equals the width of your gate.
So, Ldiff = W
As for Wdiff, this depends on the design rules as I mentioned. So you need to instantiate the layout of a unit transistor of interest, and see how wide the diffusion there is. In a 0.5 um process, this may for instance be 0.8 um.
Then, you can compute ad(as) and pd(ps) by substituting Wdiff and Ldiff in the formulae you present here.
On more advanced features:
Naturally, you need to guarantee that you are using the same diffusion width Wdiff for all transistors. The minimum is fixed by design rules, but you may make a poor layout, or have other reasons to dimension differently, and get a higher Wdiff, or not a constant Wdiff for all transistors. Moreover, if you make multi-finger transistors, then adjacent transistors share the same diffusion implant. Thus, the effective area ad(as) and pd(ps) are reduced by a factor of 2.
Vivek
xwj623
Reply #2 - Aug 20th, 2008, 12:07am
thanks vivkr.
as the figure attached,i have three questions:
1.  as=w*Ldif  , right?
2.  ps=2*(w+Ldif) or ps=w+2*Ldif ?  Is it inclued the gate edge?
    it seems that didn't consider the gate edge when calc the
    side wall cap( Csw).
3.  Does  diffusion length to gate which is called LD, has some influence?
vivkr
Reply #3 - Aug 20th, 2008, 6:05am
xwj623 wrote on Aug 20th, 2008, 12:07am:
thanks vivkr.
1. Correct !!!
2. I don't know either, but I don't think the gate edge is included. So, I would use ps=2*(w+Ldif). In any case, models which include the effect of the gate edge already will usually also include the ad/as/pd/ps parameters automatically.
3. I don't think so, but again, I don't know. Usually, LD is small and you should be able to ignore it.
But the basic form of equations you have ought to be enough to model everything quite accurately.
Vivek
xwj623
Reply #4 - Aug 21st, 2008, 12:54am
vivkr wrote on Aug 20th, 2008, 6:05am:
thanks vivkr.
1. Correct !!!
Vivek
ok. I understand.
Many thanks ,Vivek.
Reply #5 - Oct 20th, 2008, 1:07pm
BSIM4 has a parameter, PERMOD, which determines how the gate edge is computed; sometimes the gate edge junction capacitance differs significantly from the isolation edge junction capacitance.
