Jul 16th, 2024, 1:44pm
Error in iPar in Spectre (Read 2838 times)
SiValley_designer
Aug 27th, 2008, 12:01pm
I "randomly" get the following message in Spectre:
"Function 'iPar' is undefined or is used recursively"
My simulations run properly most of the times but sometimes all of a sudden this message shows up and interrupts my simulations. I think it has to do with the way spectre compiles the netlist. When it gives the error it does not replace the iPar() with its corresponding values. Does anyone have any experience with this?
« Last Edit: Aug 27th, 2008, 2:10pm by SiValley_designer »
als
Shin Yokohama, Japan
Re: Error in iPar in Spectre
Reply #1 - Sep 1st, 2008, 7:20am
SiV_D,
  iPar is used in the Analog Design Environment to allow one device
parameters to be used in the definition of another device parameter.
If iPar is being passed to Spectre, then there is an issue in the
parameter CDF.  Unlike a design variable the iPar value should be resolved before it is passed to Spectre.
