Aug 15th, 2024, 10:51am
Error using spectre (Read 2642 times)
aidnaal
Error using spectre
Aug 31st, 2008, 11:43am
Dear All,
When I want to start simulation with spectre the error says:
Fatal error: Illegal library definition found in netlist
I set the model file correctly, but I don't know why it errors!
Thanks.
Riad KACED
Swindon, UK
Re: Error using spectre
Reply #1 - Aug 31st, 2008, 3:48pm
This error occurs most likely because your spectre model file contains many sections. You need to tell to spectre which section it has to include.
I guess your netlist contains :
include "<YOUR_MODEL_PATH>/spectreModelFile.scs"
but it should be like
include "<YOUR_MODEL_PATH>/spectreModelFile.scs" section=TYP
if you want to simulate the TYP corner (or typical, SLOW, FAST ....)
If your using the ADE GUI to make you netlist, then go to:
ADE -> Setup -> Model Libraries.
Click or select the model you want to include and fill the 'section (opt)' field to choose which section you want to include.
Cheers  ;)
Riad.
Riad KACED
PDK, EDA Support Engineer.
Reply #2 - Sep 2nd, 2008, 2:46am
Hi adnaal,
If you present more details like the netlist, the log file, and so on, you probably get more helpful suggestion.
Yawei
