Riad KACED
Swindon, UK
This error occurs most likely because your spectre model file contains many sections. You need to tell to spectre which section it has to include. I guess your netlist contains : include "<YOUR_MODEL_PATH>/spectreModelFile.scs" but it should be like include "<YOUR_MODEL_PATH>/spectreModelFile.scs" section=TYP if you want to simulate the TYP corner (or typical, SLOW, FAST ....)
If your using the ADE GUI to make you netlist, then go to: ADE -> Setup -> Model Libraries. Click or select the model you want to include and fill the 'section (opt)' field to choose which section you want to include.
Cheers ;) Riad.
