Aug 15th, 2024, 7:23pm
analogLib exponential voltage source: Can I add periodicity to it? (Read 3845 times)
agaurav009
Sep 01st, 2008, 4:49am
I need a voltage source which has exponential waveoform (for realistic
rise/fall time of a clock). But since I want to use it for a clock
source, I want to add periodicity to it.
Can anybody help me?
Re:  analogLib exponential voltage source: Can I add periodicity to it?
Reply #1 - Sep 3rd, 2008, 8:31am
Don't you end up with a discontinuity because the exponential doesn't fully decay by the end of the period?
Reply #2 - Sep 3rd, 2008, 3:06pm
Perhaps you could use a pulse source to drive an RC, and then build an ideal buffer?
Reply #3 - Sep 4th, 2008, 12:06am
If you need a clock source which gives more practical rise/fall time, a voltage pulse source + an clock buffer chain is better. Normally in CMOS process, a clock is drived by one or more inverters. Smiley
Yawei
Reply #4 - Jan 2nd, 2009, 3:42pm
Or you could use a pulse or pwl source with edgetype=halfsine - this means that each transition is replaced with a half-period of a sinewave - which is a smoother transition.
