Smarty,
Can you implement the PWL in VerilogA? VerilogA can access the simulation temperature and you can write your equation for the pulse width using that value. Or, I think the there is a keyword for temperature, temp(?) so you can write expressions with temperature dependency for the PWL. If you look in the variable list for parametric analysis, the temperature keyword is listed.
