Jul 20th, 2024, 9:28pm
Parametric sweep in spectre (Read 3248 times)
smarty
Sep 05th, 2008, 4:28am
Hi All,
 Can anyone help me out on the following issue.
I am using a PWL whose pulse width is modelled depending on temperature. So if temperature increases the the high perion of the pulse increase.
I used a variable temp to define it. and if I do a parametric sweep of temp for 2 steps say 25 and 75. I see the block output not performing as desired.
If I run for the two steps seperately in analog artise, it works. Also when I change the variable from temp to any other name the block works as desired.
But I need to model using temp and can anyone suggesthow can I do that.
Thanks and Regards,
SBR
View Profile smarty smarty   IP Logged
Re: Parametric sweep in spectre
Reply #1 - Oct 3rd, 2008, 10:58am
Smarty,
  Can you implement the PWL in VerilogA? VerilogA can
access the simulation temperature and you can write your
equation for the pulse width using that value. Or, I think the
there is a keyword for temperature, temp(?) so you can write
expressions with temperature dependency for the PWL. If you
look in the variable list for parametric analysis, the temperature
keyword is listed.
smarty
Reply #2 - Oct 4th, 2008, 12:22pm
Hi Sheldon,
  Thanks for your inputs. I was able to successfully implement the same using the temp variable.
I assigned the input as a variable temp and swept the temp for different values and I was getting the desired results.
SBR
