Aug 16th, 2024, 1:25am
*E,NOTCMP problem. (Read 6046 times)
holmes
shanghai,china
*E,NOTCMP problem.
Sep 09th, 2008, 1:14am
ncvlog: *E,NOTCMP:unit divder_mdl not found while parsing.
divder_mdl is a veriloga file.
it's ok in hierarchy editor.
how can i solve it?
thanks.
Riad KACED
Swindon, UK
Re: *E,NOTCMP problem.
Reply #1 - Sep 16th, 2008, 10:34am
Hi Holmes,
Since your AMS compiles well in the HED mode, my first thought is your are defining some 'include directories' in HED and not in ADE.
If you are including verilog-A, then the compiler will look at this files in the 'include directory list'. I guess you have something defined in your HED mode : HED-> AMS -> Option -> Compiler -> Verilog-AMS -> Macros/Include -> Include Directory
If so, you need to include the same directories when working in ADE mode : ADE -> Simulation -> Options -> Compiler -> Include Path
Hope this helps.
Riad Smiley
Riad KACED
PDK, EDA Support Engineer.
Riad KACED
Swindon, UK
Reply #2 - Sep 16th, 2008, 10:43am
By The way, There is a usefull document in your cadence stream:
AMS in ADE Frequently Asked Questions:
$CDSHOME/doc/AMSinADEFAQ/AMSinADEFAQ.pdf
It's worth giving it a look Wink
Cheers,
Riad.
Riad KACED
