Nov 18th, 2026, 9:25am
Natural Log Convergence (Read 2395 times)
littlenasboy
Sep 11th, 2008, 7:19am
I'm working on a model which requires the use of the natural log operator.  The model works fine when driven with voltage sources over the entire range of operation, but won't converge when using current sources.
Here is a sample of the code...
if (ID >=0) begin
LNID=ln(ID+1e-12);
end else begin
LNID=ln(ID+1e-12);
Perhaps the derivative blows up for ID values near 0...but I don't know how to prevent that...
Re: Natural Log Convergence
Reply #1 - Sep 12th, 2008, 5:28am
I think you mistyped; the if and else blocks are the same.
You could have an issue, depending on the rest of your code, that the simulator uses an initial guess of 0 for the branch current.  Then again, maybe not, since it's the same model code independent of what's driving.
You probably need to look more closely at your probes and sources (contributions).  You might have something that looks like two current sources in series with a very slight mismatch in the sourced current.  What if you put in a huge resistance in parallel, or shrink the 1e-12 so that it's less than abstol?
